OK so now the AX trailer is done, but I still have a issue with the trailer lights being very dim to not on at all. I don't believe there is a ground problem with the trailer since the lights work when hooked up to my truck. So looking at my trusty haynes manual I am trying to figure out the pinouts for the taillights.
The both housing has three sets of pins Rf 54 58.
D side P side
Rf 54 58 58 54 Rf
0 0 0 0 0 0
0 0 0 0
I took an old housing apart. To me it looks like pin 58 goes to both the turn signal and brake light.
Pins 54 upper & lower, upper goes to brake light and lower to turn signal.
Pins Rf upper & lower,upper goes to reverse light and lower to the gound bar of the light housing
So..... a standard flat 4 wire trailer plug you have white, brown, yellow, and green. White is ground, brown is running lights, yellow is Lt turn & brake, and green is Rt turn & brake.
Are you with me so far
So how should I have the 4 wire plug wired into my taillights?
