Allan
Feb 22 2006, 01:17 PM
Does any body know where I can get a set of plugs for the air injection ports on the heads for a 2.7?
Or what size they are?
I need em quick!!!
Allan
Feb 22 2006, 01:30 PM
They are a 10 x 1.0
Performance products is suppose to carry them but they don't answer the phone.
ArtechnikA
Feb 22 2006, 03:29 PM
QUOTE (Headrage @ Feb 22 2006, 03:30 PM) |
They are a 10 x 1.0 |
in which case, that's the same as our brake ports.
i got a nice set of brake-port sealing plugs with a VW part number a while back. i'd never find that number now, but it'd give you another application to look for. i'll try to post a photograph tonight...
John
Feb 22 2006, 04:12 PM
Pelican sells hex head Rear Brake port bolts which work well if you can get the damn air injectors out without snapping them off.
I don't know how much they are, but they fit and have a sealing ring with them.
J P Stein
Feb 22 2006, 05:48 PM
EBS
Allan
Feb 22 2006, 06:01 PM
Okay, I got them on the way. Unfortunately they will not get here until Friday so I looks like it'll be next week before the car is ready.
And yes, EBS was the place.
Thanks Cap'n and JP...
Cap'n Krusty
Feb 22 2006, 06:16 PM
They can be installed with the engine in the car. BTDT, LOTS of times. However, a week's time is pretty unrealistic to assemble and install a 911 engine unless EVERYTHING goes right. How often does THAT happen?
Porsche Rescue
Feb 22 2006, 06:18 PM
I used the plugs suggested (and provided) by sixnotfour.
1/8 pipe allen plug. Works fine. I'd make it easy on myself and go to the ACE Hardware man.
Edit: hey, where did his posts go?
Allan
Feb 22 2006, 06:27 PM
QUOTE (Cap'n Krusty @ Feb 22 2006, 04:16 PM) |
However, a week's time is pretty unrealistic to assemble and install a 911 engine unless EVERYTHING goes right. How often does THAT happen? |
Bottom end is done. Heads are done. New P/C's. Been 7 weeks.
Should be done within a week I would think.
And where did Jeffs posts go?
I was gonna go the pipe plug route if I didn't find em this afternoon.
