r_towle
Feb 23 2006, 04:47 PM
So, I tried several gentle methods to remove the letters from an old lid.
I pried, I used a flat bladed knife..I used a heat guy...
All attempts had the same results...I broke the plastic post off the back of the letters....
So, any ideas on a good way to remove good letter,,,and try ti save the post?
Rich
VegasRacer
Feb 23 2006, 04:48 PM
Thrash / cut / bend the clips.
Destroy them and save the post.
double-a
Feb 23 2006, 05:24 PM
those rubber fasteners are designed as "one-time" use i believe. i used pliers and smashed them up real good to get them off.
but you're at a disadvantage with those plastic letters, the posts break really easily. i opted for a set of shiny metal letters when i refurbished my engine lid.
~a
jim_hoyland
Feb 23 2006, 05:39 PM
Where are metal letters available from ?
double-a
Feb 23 2006, 05:46 PM
i think i got mine from the bird, maybe a year ago.
~a
914Sixer
Feb 23 2006, 09:24 PM
I use a small set of diagonal pliers to cut them in two pieces . You can then bend the metal part of the washer out of the way.
All the early cars 70-73 had metal letters. I have lots of used letters if you need replacements. Most are gold anodized others are sliver depending on the year.
william harris
Feb 23 2006, 10:20 PM
Rich: I got a spare set of silver letters in my parts bin. They have your name on them for free. Come by and pick them up or let me know your address and I will drop them in the mail to you - no charge. P.S. this is a good set, no broken posts. I also have a small lot of the clips, probably enough for the letters. Will send what I have. I owe you.
