I was cruising through the Performance online catalog and came across the Weltmeister Air Line Plugs available for when you remove the air-pump on the sixes.
Are these the same size lines as are on the 914 2.0? Mine is a 76, and the pump has been dead for years. It is time to pull the whole mess this year, and clean up the engine bay a bit, so I thought this might be a good solution.
Has anyone used these, or are they available from elswhere at a non-Performance price.
Thanks in advance for the replies.
TC
