michel richard
Feb 25 2006, 06:56 PM
How much do they sell for ? If nobody has one, a picture might help recognize one if I bump into it at Hershey.
mg911guy
Feb 26 2006, 01:25 AM
Michel, Do you mean the pump that was attached to the 6/Camshaft? I have one of those. I will take some pic's.
IIRC they used the same one on early Turbos for oiling.
Mark..
mg911guy
Feb 26 2006, 02:02 AM
Pics
mg911guy
Feb 26 2006, 02:03 AM
Is this what you need?
thesey914
Feb 26 2006, 04:13 AM
Mark do you have a picture of the bolock-off plate you used when you removed pump?
michel richard
Feb 26 2006, 09:46 AM
Yes, that is what I'm looking for. Is yours for sale ?
thesey914
Feb 26 2006, 10:33 AM
Michel, are you after the sporto pump for twin plug purposes? I have one if no others are forthcoming
michel richard
Feb 26 2006, 10:44 AM
I'm after the pump for transmission cooling purposes. I'll be putting 250 hp through a 901 transmission, which is pretty much the limit. I understand that when the factory put a cooler on those transmissions they used that sporto pump to circulate the oil.
I won't be doing a lot of track, though, so the cooling may not be really necessary. On the street, max horpower is used only for very short periods of time, and I would think that torque is then the limiting factor.
Still, there's the cool factor that I like. (pun sort of intended).
James: Brian spoke up first, so I'll see if his is for sale, but thanks for the offer.
Cheers.
Michel
mg911guy
Feb 26 2006, 11:37 AM
Michel, You can have it. It was in a box of parts from the PO of my 911.
PM me...
Mark...
michel richard
Feb 26 2006, 12:12 PM
Mark,
p.m. already sent. Thanks
Bleyseng
score!!!
mg911guy
Feb 26 2006, 03:29 PM
Michel, PM Sent Mark...
michel richard
Mar 7 2006, 06:53 PM
Mark delivered as promised, at a very, very reasonnable price i.e. FOC.
This board rocks.
I'll be posting more in the future about the use of a sporto pump to circulate oil around a 901 transmission and a cooler.
Michel Richard
iamchappy
Mar 7 2006, 07:22 PM
I fabbed up a similar pump ( turbo scavenge ) on the back of my cam. Just drill and tap two holes opposite each other on the end of the cam and loctite in a pair of allen head cap screws.
michel richard
Mar 7 2006, 09:10 PM
It did take me a couple of minutes to figure out how the pump is driven. The holes already are in the camshaft. I believe the factory way is simply to press some pins into the shaft. I'll see.
I think I have the MFI drive sprocket housing that was designed to mount the sporto oil pump like in the picture. I could never figure out what that part was. Now I just need to find it ! I may want to keep the option of going back to MFI as a future project.
michel richard
Mar 7 2006, 09:17 PM
and so:
Thanks to Eric of Ashburn, Virginia on the Pelican board for posting the pictures there.
iamchappy
Mar 7 2006, 09:39 PM
I believe the holes in the camshaft are there to relieve pressure. Those were the holes I used I tapped them and drilled another hole to relieve pressure. If I did it over again I would leave those holes already there alone, and drill and tap two shallow holes in the cam end.
iamchappy
Mar 7 2006, 09:42 PM
turbo pump
iamchappy
Mar 7 2006, 09:45 PM
My cooler with Tilton electric pump
