Jaiden
Feb 28 2006, 11:03 AM
So I got a another a-arm but the end cap is missing is it even possible to replace this?
Eric_Shea
Feb 28 2006, 12:47 PM
Yes, they're available. Call PP and ask for the torsion bar end cap. They used to have them in the online catalog. If not call Porsche... only a couple bucks each.
Spoke
Feb 28 2006, 01:13 PM
James,
Did you need the end cap? It should still be sitting around the garage if you want it. The adjustment bolt is sitting in the red car; looked at it last night. The end cap can't be far away. My buddy in Andreas (near New Ringgold) had a bunch of suspension parts. I'm going to call him tonight to see about a replacement rear trailing arm. I can ask him if he has any if you would like.
Spoke
Jaiden
Feb 28 2006, 04:18 PM
Thanks guys,
How do you install the cap?
On my original A-arm I appears that it was pressed in and then the end was clamped in place.
There was a plastic shim there but no metal cap.
You guys know what I mean right? On the front end not the torsion adjuster.
Thanks again spoke let me know if you find it.
r_towle
Feb 28 2006, 04:24 PM
From what I recall, its just pressed in.
I took mine out to remove the torsion bar...then just put it back in...carefully.
I have a few cars worth of suspension if you need something..
If you can wait, I am going to Hershey...
Rich
Eric_Shea
Feb 28 2006, 04:30 PM
yup... just pressed in. You may want to whack it with a plastic mallet to spread it out a bit and hold it tight.
