Albert914
Feb 28 2006, 11:28 PM
I have stock 914 rotors drilled to 5 lug in the rear. I just bought 914-6 rotors. how much does the OD need to be machined? The thickness is also larger. Will this fit in the stock calipers? I put the 914-6 rotors on the drilled out axles and the set screws did'nt line up. should I drill and tap new holes? Any information would be apprecitated.
Aaron Cox
Feb 28 2006, 11:31 PM
they should fit inside the calipers NO problem....
im running the same setup, and i didnt touch the OD of the rotor... or the caliper....
worst case scenario, sand/file/grind the caliper, so you dont have to machine everyset of rotors....
Type 4 Unleashed
Feb 28 2006, 11:51 PM
I, have 914/6 rotors on my car, they are a little larger, but still fit the 914/4 rotor. The only thing, the 914/4 brake pads, don't ride the the edge of the rotor, apparently smaller.
You, could drill and tap for set screws, I, didn't.
