obscurity
Mar 3 2006, 09:38 PM
Ok so I am relatively new to automobile electrical and my car 914 won't start. This is what I get:
with the ignition on, when I manually open the points I can get the coil to spark.
When I open the points by using the starter to turn the engine over I get no spark from the coil
The car is a '71 914-4 1.7 that has sat for 8 years but ran when it was parked
Any ideas would be appreciated
Mar 3 2006, 09:46 PM
QUOTE (obscurity @ Mar 3 2006, 07:38 PM) |
Any ideas would be appreciated |
did you watch the points when cranking the starter? do they actually open? maybe all you need is an adjustment ...
just an idea ...
Andy
obscurity
Mar 3 2006, 09:50 PM
they are definitelt opening and closing. I get little sparks at the points when they open but nothing at the coil
Mar 3 2006, 09:52 PM
QUOTE (obscurity @ Mar 3 2006, 07:50 PM) |
they are definitelt opening and closing. I get little sparks at the points when they open but nothing at the coil |
coil could be bad, do you have a spare one you can try?
Andy
PS: i'm just throwing ideas at you, i don't really have a clue as to what could be wrong ...
obscurity
Mar 3 2006, 09:56 PM
The coil that gives the spark is actually a spare I had from my VW bug. Its old but as far as I know it is still good. The original one I took out of the car gave a very weak spark
lapuwali
If you're getting sparks at the points, they're arcing. The condensor is dead, or the points gap is way too small. The gap is in the Haynes manual, and is easily adjustable if you have a feeler gauge.
obscurity
Mar 3 2006, 10:03 PM
I can't find my feeler guage but I set the gap to .016 (haynes) with a blade from something that measured .017 with calipers. I'll try replacing the condenser in the morning. I may also replace the points and coil just for good measure. Is it possible to do this with the distributor in the car?
lapuwali
Mar 3 2006, 10:29 PM
QUOTE (obscurity @ Mar 3 2006, 08:03 PM) |
I can't find my feeler guage but I set the gap to .016 (haynes) with a blade from something that measured .017 with calipers. I'll try replacing the condenser in the morning. I may also replace the points and coil just for good measure. Is it possible to do this with the distributor in the car? |
yes.
