Finally got my car to a point where I could get the car off the jackstands and give it a little drive. First of all, the car seems much more torquey with the header .
Need to get my track pads into the M calipers but they seem to work pretty well even with the old pads in place.
Man was that proportioning valve a bear to get out with the motor installed.
Didn't think I was ever getting that thing off the firewall and getting the three lines off. Once I finally got it out of there the T went in with very little effort. Just needed to rearrange the lines slightly to get everything to line up.
Much easier to bleed the brakes now
Next up will be the oil cooler. Probably going into the floor of the front trunk. Will open up the plugs in the front bulkhead and open up a hole in the floor the size of the 25 row mocal cooler. I also have a 1600CFM fan hooked up to push ambient air thru the cooler when going slow. I will have it hooked up to the now useless fog light switch.
almost done.....er, does that ever really happen?
