Mike McGrath
Mar 4 2006, 04:52 PM
I have to get my seats recovered, but someone is offering two reupholstered seats for a lot less. I'm assuming the 1970 backpad has to come out and I may have to weld / attach the passenger seat so it can move forward and back, but is there anything else I am forgetting? Also, how hard is it to find a backpad for the later model 914s?
TIA,
MIke (in Portland)
jetboy
Mar 4 2006, 05:03 PM
Im curious about this too. Although, i wonder if much needs to be done for just a stationary passenger seat (move drivers seat to passenger side).
SLITS
Mar 4 2006, 05:07 PM
You need:
Backpad
Hinge mounts for rear of seat
Hinge mouts welded to body
Seat bracket with tilt
Tilt teeth bracket
Weld tilt bracket to crossmember
That should be it.........
lapuwali
Mar 4 2006, 05:42 PM
You need an actual passenger side seat, too.
Later backpads will show up used from time to time. I may have one for sale in a few weeks, as I may be converting to a carpeted firewall.
Porsche Rescue
Mar 4 2006, 05:53 PM
Call Craig at Camp 914. He has a back pad for sure. Likely has the other stuff from a parts car as well. Camp is in Oregon City near Clackamas CC so no shipping to deal with. You can look at one of his rollers and see what needs to be done.
jetboy
Mar 4 2006, 06:15 PM
QUOTE (lapuwali @ Mar 4 2006, 03:42 PM) |
Later backpads will show up used from time to time. I may have one for sale in a few weeks, as I may be converting to a carpeted firewall. |
If your converting to a carpeted firewall, what are you going to use for the passenger seat? And what are you going to have to do to install it?
lapuwali
Mar 4 2006, 08:35 PM
A PO converted my '71 to a later passenger seat, including a later backpad. As stated, this just involves getting the later bits welded in. The backpad, once out, will just be replaced by a sheet of lightweight carpet, glued to the firewall.
