malaga_red75
Mar 6 2006, 12:01 AM
Hey guys. This is my first post and I was hoping some of you guys could help me out. I have a 75 1.8 914 and obvoiusly with only 73 hp, I could use some more. I was wondering what things i could do to get some more horses out of it. I would prefer not to do a conversion as I am on a budget, but any ideas would be great!
anthony
Mar 6 2006, 01:16 AM
Unfortunately, there isn't much you can really do.
The cheapest thing is a free flowing exhuast. Heat exchangers from a 73-74 2L engine and a new exhuast will free up some hp.
Mostly everything else requires tearing into the engine and bringing lots of money.
alpha434
Mar 6 2006, 01:28 AM
Someone told me that there where 25 different releases of the L-jet. And that The best version made a LOT more than 73 hp.
I'm stuck with a 75 L too. And I outrun 1.7s pretty easy. Played with a 2.0 once too. But he said that his car "wasn't working properly" when I nailed hi on a straight. I think I've got pics. One of our guys got arrested that day....
Brando
Mar 6 2006, 02:35 AM
for less than $500 you can keep your stock injection and heads, throw some 96mm Pistons and Cylinders under there. a 1911 with L-Jet and some bumped compression should make an even 95 or 100 with the early 2.0 headers as mentioned. Go for SSIs and a bursch exhaust. Should keep you under a grand if you don't mind pulling the engine.
Bleyseng
Mar 6 2006, 09:13 AM
QUOTE (Brando @ Mar 6 2006, 12:35 AM) |
for less than $500 you can keep your stock injection and heads, throw some 96mm Pistons and Cylinders under there. a 1911 with L-Jet and some bumped compression should make an even 95 or 100 with the early 2.0 headers as mentioned. Go for SSIs and a bursch exhaust. Should keep you under a grand if you don't mind pulling the engine. |
Maybe 90hp if you do a cam change too say the Raby 9950 with lifters. 96mm isn't gonna make 100hp or atleast I haven't ever seen a dyno sheet to make it a fact. The heads also limit the hp.
So to make so hp on a 1.8l
Switch to 96mm pistons and cylinders ( they are special ones to fit the 66mm stroke)
Switch out the cam and lifters to a Raby 9550 cam with lifters ( oil temps will go down)
alpha434
Mar 6 2006, 10:32 AM
Ok then. Who here knows the cam specs for 1.8?
You can port and polish the heads too. That's a VERY cheap upgrade if you do it yourself. Real easy horsepower if you take out enough material.
Bleyseng
Mar 6 2006, 10:54 AM
QUOTE (alpha434 @ Mar 6 2006, 08:32 AM) |
You can port and polish the heads too. That's a VERY cheap upgrade if you do it yourself. Real easy horsepower if you take out enough material. |
Thats not going to make much of a difference if you still are using the stock cam. Polishing the ports does jack as the injectors are pointing right at the valve. You can also destroy the heads pretty quickly if you do it yourself!
Better Airflow is achieved by a BETTER cam as the stock cam is very mild (same as the Djet cam) and set up for quick warm ups and running fairly hot for emissons.
The 1.8heads are ok valve size wise but the spark plug location is better on the 2.0l heads.
Raise the compression ratio to 8 to one with the 96mm's
anthony
Mar 6 2006, 11:02 AM
For me there are too many "while you are theres" in just fitting new P&Cs. And how much hp do you get out of 96mm P&Cs with no other changes? Like 5hp? 10hp max?
Once you tear it all down it will be a shame not to have the heads refreshed. You'll probably find cracks or strip a stud which will mean sending the heads out anyway. You'll probably find that you want a new clutch ($500). The flywheel may have seen better days ($300). DWD sets in and two years and $3,000 later you've powdercoated and polished the engine compartment and rebuilt half the engine for a 10hp improvement. :-)
If I was going to put $1000 or $2000 into a 914-4 that was running good I'd first work on the suspension. With some good shocks (Konis or Bilsteins), a 19mm sway bar up front, 140lbs rear springs, and maybe turbo tie rods you will have a car that rides on rails. It may be underpowered but you can go fast in and out of turns.
After that if you really want more hp I'd consider the following order:
1911 top end upgrade (96mm P&Cs) $1500
2056 kit $3000
2270 kit $5000
six conversion $6000-7000+
Bleyseng
Mar 6 2006, 11:12 AM
find a good used 2.0l and drop it in, now thats the cheapest hp increase for about $800-1200
Cap'n Krusty
Mar 6 2006, 11:13 AM
QUOTE (alpha434 @ Mar 5 2006, 11:28 PM) |
I'm stuck with a 75 L too. And I outrun 1.7s pretty easy. Played with a 2.0 once too. But he said that his car "wasn't working properly" when I nailed hi on a straight. I think I've got pics. One of our guys got arrested that day.... |
25? True, if you count the Jaguar XJ6, the 280/300 ZX, and a buncha other cars. They have more power. Of course, SOME of that power comes from larger displacement and stuff like that. The Cap'n
Cap'n Krusty
Mar 6 2006, 11:15 AM
Jake will probably agree with me that we've seen a LOT of home port & polish jobs that actually resulted in LESS HP. The Cap'n
Jake Raby
Mar 6 2006, 11:25 AM
The Capn is exactly right...
If you can't afford a professional (that knows ONLY TIV heads) leave the ports alone.
Altering ports has the capability of altering port margins which can easily result in an engine that runs like crap, is untunable and rins hot.
Do it right, or leave it alone.
newto914s
Mar 6 2006, 03:12 PM
Bleyseng you've recommended the Raby 9950 Cam twice in two days. What's so special about this cam. Its identical to a stock D-jet cam right? I was always under the impression only a stock cam will work right with D-jet
OK, hijack over
malaga_red75. My car was once Malaga Red too, and will be again one day. Post some pics of your car
Samson
bd1308
Mar 6 2006, 03:30 PM
No, the 9950 is a cam "optimized" and warmer than the stock cam IIRC.
b
Andyrew
Mar 6 2006, 03:37 PM
Um...
A turbo?
Many guys do it on the cheap.. Do it for 500 bucks if you got the skills... Blow the engine? get another $500 engine!
Repeat if neccisary!
Bleyseng
Mar 6 2006, 04:54 PM
QUOTE (newto914s @ Mar 6 2006, 01:12 PM) |
Bleyseng you've recommended the Raby 9950 Cam twice in two days. What's so special about this cam. Its identical to a stock D-jet cam right? I was always under the impression only a stock cam will work right with D-jet OK, hijack over malaga_red75. My car was once Malaga Red too, and will be again one day. Post some pics of your car Samson |
Its a different grind that produces more hp and less oil temps. I think its upto Jake to state the grind specs online as its his produce. I will say I noticed a real seat of the pants difference from the stock cam as I just got my 2056 running again after replacing the cam in it.
I also have installed one in the 1.7L engine that I am working on for Blairs 914.
I finally got mine to idle right this weekend but that was due to other problems. Runs great with nice torque in the low revs and power seems to peak at 5000 rpms and revs easily to 6500.
newto914s
Mar 6 2006, 05:22 PM
So it's a cam that idles and runs smoothly with stock Fuel Injection, but gives you a little more power and cooler temps. Oh, and a few more revs. Sounds to good to be true
Jake Raby
Mar 6 2006, 05:31 PM
Whats special about the 9550 cam is that it was designed specifically for stock FI optimization for engines up to 2056cc.
It has a very mild intake ramp and adds a bit of exhaust duration to balance out the equation and provide a broader power range.
This cam is perhaps the most effective cam I have ever designed and it sells 6 times more than any of my other grinds!
People have fallen in love with this cam profile.
brant
Mar 6 2006, 05:41 PM
I'll throw in my 2cents...
I don't think the original poster wanted to rebuild his motor...
so I'll agree with the tune up suggestion and then spend the last 400 on a set of 50series tires.
the lower profile will give you lower gearing and quicker seat of the pants acceleration...
If you have any extra money left over spend it on suspension items.
brant
grantsfo
Mar 6 2006, 05:44 PM
First off make sure everything related to FI including injectors are working correctly. Headers will free up a suprizing amount of hp in the 1.8 if youre willing to give up heat. Shedding rotational weight helps a lot too. Lightened flywheel will help the engine. My 914 that is currently being converted to a six was just a well tuned stock 1.8 with headers and it was suprizingly fast.
Dont forget that while the engine was only rated at 76 hp it made impressive torque. Giving the 1.8 breathing room makes all the differnce in the world.
newto914s
QUOTE (Jake Raby @ Mar 6 2006, 03:31 PM) |
People have fallen in love with this cam profile. |
36-24-36 and a cute face, sounds like love to me.
Jake, do you have any output graphs of that cam in a 2.0?
Jake Raby
Mar 6 2006, 05:47 PM
sure, email the mad scientist.
productdevelopment@aircooledtechnology.com
malaga_red75
Mar 6 2006, 08:27 PM
Thanks alot for all the input! I already have a bursch exhaust on it but I am looking for some headers. Can you guys give me a brand and maybe a website that sells them. I am willing to spend around 1000 or maybe a little more, but maybe some headers and suspension will be just what i need. My picture files are too large to put in here, I will take some more pictures tomorrow with my new rims that came today!!!!! 15x5.5 reproduction fuchs black/silver from American Eagle. keep the ideas coming. Also any more info on the turbo system?
-Peter
jd74914
Mar 6 2006, 08:50 PM
QUOTE (Jake Raby @ Mar 6 2006, 06:31 PM) |
QUOTE (newto914s @ Mar 6 2006, 01:12 PM) | Bleyseng you've recommended the Raby 9950 Cam twice in two days. What's so special about this cam. Its identical to a stock D-jet cam right? I was always under the impression only a stock cam will work right with D-jet OK, hijack over malaga_red75. My car was once Malaga Red too, and will be again one day. Post some pics of your car Samson |
Is the 9550 for DJet? What would you recomend as an upgrade cam for a 1.8 with Ljet?
Bleyseng
Mar 6 2006, 08:56 PM
The 9550.....I am putting one in my Westy for Christsake! Its got the Midastouch.
Jake, can I get a $1 for every time I recommend this cam?
I gots to get the local guys to drive my car so they can chime in.......Maybe DaveHunt and KevinP.
Suspension tricks? Buy a set of Koni Yellows and then go AXing in stock class and whipass.
jd74914
Mar 6 2006, 08:58 PM
QUOTE (Bleyseng @ Mar 6 2006, 09:56 PM) |
just makin sure before i pull the trigger
Bleyseng
Mar 6 2006, 09:01 PM
Buy the cam and the lifters from Jake. Noshit, its the real deal.
jd74914
Mar 6 2006, 09:03 PM
Thats the plan. Maybe some 96s as well
Andyrew
Mar 6 2006, 09:09 PM
Dave_Darling
Mar 6 2006, 09:46 PM
QUOTE (malaga_red75 @ Mar 6 2006, 06:27 PM) |
...I am looking for some headers. Can you guys give me a brand and maybe a website that sells them. I am willing to spend around 1000 or maybe a little more... |
I know of four sources of headers that "work".
First, and cheapest, is http://www.kerryhunterenterprise.com
The next two seem to be "around" equivalent in performance and in price to each other. Better and more expensive than the KH ones. European Racing (no website that I know of, but the phone number has been posted on this forum before) and Triad West Performance. http://www.triadwestperformance.com/
Finally, the best--and most expensive--system is from Racer Chris over at Tangerine Racing. http://www.tangerineracing.com
None of them are overly cheap.
--DD
malaga_red75
Mar 6 2006, 10:19 PM
On the mufflers, I already bought a bursch muffler not that long ago, and would want to keep it as i dont want to waste 200 bucks. Is there any header systems that are still applicable to the 'stock' exhaust mounts, or do I have to get a whole new set up. ALso- how do I get large pictures up here. My pictures are all larger than the allotted 300,000 bytes.
-Peter
Bleyseng
Mar 6 2006, 10:24 PM
if ya got XP, open the pic and right click and see the "resize", click on that and pick small. Then back to the BBS and reply and hit the "Browse" button to find your smaller pic.
malaga_red75
Mar 6 2006, 10:51 PM
when i right click i am not given that option. what are u opening the picture in?
Bleyseng
Mar 6 2006, 11:11 PM
no program, just XP's default pic viewer.
you can resize in Photoshop Elements, Infanviewer etc ....
Dave_Darling
Mar 7 2006, 09:22 AM
QUOTE (malaga_red75 @ Mar 6 2006, 08:19 PM) |
Is there any header systems that are still applicable to the 'stock' exhaust mounts... |
Nope! The real header systems replace everything, and are not compatible with stock-replacement mufflers.
--DD
Joe Ricard
Mar 7 2006, 10:26 AM
QUOTE (Bleyseng @ Mar 6 2006, 06:56 PM) |
Cam is a "not equal to stock class rules" No matter who makes it cept for VW/Porsche. STOCK cam
Raby cam ???? Welcome to Street mod 2 hope your heavy enough. 2100 pounds = fat pig of a teener.
Bleyseng
Mar 7 2006, 11:03 AM
Yeah, but who can tell if you are running the stock FI.
If he wants suspension upgrades the Yellow Konis is the place to start instead of sway bars, Tbars etc as you can run (here atleast) in stock class with any shock. Drive the 1.8L with yellows in Stock class and learn how to drive.
Then get a higher hp motor.
Don't do what JP did. Buy and high hp motor and then try to learn to drive it.
Jake Raby
Mar 7 2006, 12:42 PM
OR just cheat like the competetitors!
Joe Ricard
Mar 7 2006, 01:21 PM
I usually run tech at our regional events. If I suspect anything I can usually sucker in the proud owner to bragging about his motor.
" Oh really" what else did you do? cool, yea I wanna get something like that. Cam? some port work in the heads really ?
WELCOME TO STREET MOD Next car please.....
Bleyseng
Mar 7 2006, 03:02 PM
Shoot, our tech guys just check to make sure the battery don't fly out, the wheel bearings aren't too loose and ya got 4 tires with air in them.
malaga_red75
Mar 7 2006, 11:36 PM
THanks alot for the suggestions, I let my mind run wild last night and was wondering if anyone had done a 914-6 conversion but to a newer 6 cylinder. Im talking like a 2000 or late 90's 6 cylinder. I think that would be a way to get great HP without the V8.
McMark
Mar 7 2006, 11:39 PM
We've got about 4 3.6 conversions going right now on this site.
Mueller
Mar 8 2006, 12:11 AM
QUOTE (malaga_red75 @ Mar 7 2006, 10:36 PM) |
THanks alot for the suggestions, I let my mind run wild last night and was wondering if anyone had done a 914-6 conversion but to a newer 6 cylinder. Im talking like a 2000 or late 90's 6 cylinder. I think that would be a way to get great HP without the V8. |
the mid to late '90's motors are great....figure $7,000 just for the engine....then add a few more grand to install it (parts only, not including labor)
