Does anyone know where I can find a fuel filter with 9mm in and 7.5mm out for injection?
I have a '72 with carbs i'm converting to megasquirt.
The stock filter location is before the pump right? The fuel pump has 3 7.5mm connections, correct?
I'm in the process of replacing my fuel lines. The feed is 3/8" and the return is 5/16". I already have a 3/8" filter I bought from summit, what's the best way to get it down to 5/16"?
I've searched and searched... I don't know of any local VW shops around here.
Someone on here mentioned the bosch box style fuel filters can leak after time. Is this common?
Thanks
