I bought a pair of H4 Cibie lenses and the Hella H4 55/100watts bulbs. I also bought from Pelican their high power headlamp relay.
The mechanic working on the car indicates that this relay will always return to its set state after releasing the change light lever. That is, if it is set for low beam, it will change to high when pulling on the lever, but returns right back to low when releasing the lever. The inverse will happen if set to high.
How to make the lights remain in low or high as desired?
He also recommended a change in wiring for this upgrade. According to him, the higher current required for the H4´s may be too much for stock 30 year old wiring. Is he correct?
