Mueller
Feb 19 2003, 06:38 PM
Anyone have this number or know the dimensions (bar dia, and distance from the centerline of the bar to the centerline of the mounting point on the rear shock) so that I can figure it out?
campbellcj
Feb 19 2003, 06:42 PM
I have a welt 16mm rear bar sitting in my garage if that would help.
airsix
Feb 19 2003, 06:56 PM
QUOTE(Mueller @ Feb 19 2003, 04:38 PM)
Hey Mike, I've got a stock bar hanging on the wall in the garage. I'll throw the calipers around it tonight and let you know the diameter. I'll run a tape from end-to-end too.
-Ben
ps - thanks again for the door stay.
pps - Like my avatar? That's my hunt'n partner. We really terrorized the bunnies Saturday. We've been working together since November and he still doesn't have a name. Anybody got any ideas?
Mueller
Feb 19 2003, 07:12 PM
Hey Ben....
Neat bird.....not too far from where I live I see some guy in the morning training his hawk/falcon.....
drew365
Feb 19 2003, 07:14 PM
My rear Welt is 16mm also. Don't know the other dimensions. I'll be under it tonight, if no one else posts I'll grab a tape.
Mueller
Feb 19 2003, 07:28 PM
The dimensions I am looking for are A or B,
it depends on which portion of the bar on the top area that gets mounted to the car....I have no swaybar to figure that one out
jonwatts
Feb 19 2003, 07:55 PM
QUOTE(airsix @ Feb 19 2003, 04:56 PM)
Mr. Peepers
Bleyseng
Feb 19 2003, 08:06 PM
A=12"
16mm bar
Geoff
Alfred
Feb 19 2003, 08:11 PM
Killer?
Alfred
ChrisReale
Feb 19 2003, 08:22 PM
Hi Air Six, where abouts do you live in Eastern wash? I might be cruising around there in my 914 when the weather clears up. Id love you see your falcon in action if possible....
Jeroen
Feb 19 2003, 08:32 PM
Darn, it's cold in the garage...
The bar diameter is 16mm
Dimension A = 280mm (center of the bar to the center of the droplink mounting eye)
Dimension B = 320mm (center of the bar to the center of the droplink mounting eye)
HTH,
Jeroen
Tony C
Feb 19 2003, 11:41 PM
Mike, Also keep in mind when figuring out spring rates, the endlinks bend, the bushings compress, and "heat treating" varries. Except for the "speedway engineering" type bars it is very hard to get very close to the real installed spring rates when trying to calculate the spring rate.
-Tony
airsix
Feb 20 2003, 01:34 AM
Guess I should have stayed home Saturday and cleaned the garage. I can't find my caliper or my metric tape. Sorry you'll have to convert I guess.
A = 11 3/8" (from bar center to center of pivot ball)
B = 12 15/16" (from bar center to center of pivot ball)
Distance between pivot balls = 34 7/8" (measured to center of balls)
Overall width (elbow to elbow) = 43 7/16"
Distance between chassis mount points (based on bushing wear marks) = 39 1/2"
Hope that helps.
-Ben
JWest
Feb 20 2003, 07:27 AM
Just to clarify, it mounts at the "A" portion so that is the relevant dimension.
