ChrisReale
Sep 8 2003, 08:45 PM
Bolted the stubbies up ok, bolted the header pipes up ok, but the 4 to 1 collector was hard to slide onto the pipes. Is it necessary to get it on there so you can bolt the collector to the two pipes? How would I get it to slide on easier?
Ran the car with the megaphone on----loud
Bleyseng
Sep 8 2003, 08:48 PM
I shoved the 4 pipes into the collector first then installed the pipes to the stubbies. Run it without the megaphone, waaay cool!
Geoff
ChrisReale
Sep 8 2003, 08:51 PM
Geoff, did you bolt the collector to the two pipes with the holes?
Bleyseng
Sep 8 2003, 08:59 PM
What two pipes with holes?
Geoff
ChrisFoley
Sep 8 2003, 09:02 PM
I would think that if you attach the pipes loosely to the stubbies the collector would fit without too much trouble. After everything is assembled, then tighten all the bolts.
Brad Roberts
Sep 8 2003, 10:19 PM
Foley nailed it. Assemble loose and tighten later.
B
ChrisReale
Sep 8 2003, 11:49 PM
Im too full from dinner to get down and take pics. The collector has two prongs to bolt the collector to two of the pipes. Ill loosen up everything and tiighten when its all assembled. I knew I should have done that, I was really excited to get it on!
rhodyguy
Sep 9 2003, 06:12 AM
megaphone huh? must be reale loud. he he. you're going to get good r&r-ing. h.e. weather is just around the corner.
kevin
KenH
Sep 9 2003, 09:51 AM
Now you need a "Phase 10" muffler from "Tangerine Racing" or "Quiet Power".
Ken
machina
Sep 9 2003, 10:31 AM
I am running the triad header and muffler. Muffler is well built and meets sound requirements.
david
ChrisReale
Sep 9 2003, 10:55 AM
Thats a cool muffler. I have never seen one of their header mufflers. Thanks for the pic!
Brad Roberts
Sep 9 2003, 11:51 AM
Cough...cough..um..cough.. cherry bomb..cough..
B
Bleyseng
Sep 9 2003, 11:57 AM
Nice if you lose the rear valence.
My muffler from Eurorace exits into the stock hole.
Geoff
ChrisReale
Sep 9 2003, 12:41 PM
I just got everything bolted up. The Eurorace muffler, like the pic Geoff posted exits the stock valence. It sounds killer! Low throaty rumble. I need to tie up a few loose ends (all the heater stuff I doan need!) and let it cool down and then I go for a drive!
Aaron Cox
Sep 9 2003, 03:17 PM
could you fab dual cherrybombs for a /4 ? what sound / performance increase would that make?
Brad Roberts
Sep 9 2003, 04:36 PM
Its called a Triad Aaron. It sounds good.
B
ChrisReale
Sep 9 2003, 04:59 PM
What do you do about the clutch and speedo cable? It stinks when the housing burns....
Exhaust tape?
Brad Roberts
Sep 9 2003, 07:53 PM
I ceramic coat the header...
Ok ..Ok..
Look at the side of your engine block (passenger side).. see the little threaded tab hanging off the block (warm air guide used to mount to it) I use a clamp with a hole in it for a bolt and put it around the cables. This keeps the cables off the header.
B
Bleyseng
Sep 9 2003, 09:16 PM
DAmn, I did good as I already figured that one out without Brad telling me. I used a wiretie to snug it to the motor away from the header.
Geoff
Brad Roberts
Sep 9 2003, 09:21 PM
Dont use a zip tie.. they melt...LOL
Safety wire works well also.
B
seanery
Sep 9 2003, 09:33 PM
I've been wanting a safety-wire twister tool thingy.
Where can I get a decent one for a decent price?
ChrisReale
Sep 9 2003, 09:35 PM
Ahhhh....I see.....I gotta do some drilling/tapping because One of the exhaust studs stripped its hole out. I have another exhaust leak
Brad Roberts
Sep 9 2003, 09:37 PM
Learn to use a 1/4 inch drive ratchet and sockets on the exhaust nuts. This will keep you from over torquing the nuts and pulling studs out (not enough leverage to hurt anything using 1/4 inch drive stuff)
B
Bleyseng
Sep 9 2003, 10:19 PM
I use tie wire and wire pliers that I use when I tie steel (rebar). Got tons of it laying around from work.
Geoff
ChrisReale
Sep 10 2003, 12:22 AM
QUOTE(Brad Roberts @ Sep 9 2003, 08:37 PM)
B
Sound advise. i will keep that in mind. I have a question on drilling and tapping. I have a stud that is 8mm one side, 9mm on the other. In a perfect world, I would get a drill bit that is slightly under 9mm in diameter, and tap, but since this is not the case, what size drill bit would be used?
MarkV
Sep 10 2003, 12:33 AM
You need to look at a chart 8.1mm drill for 9mm tap .1mm pitch (decimal equivalent .3189" drill).
chart
ChrisReale
Sep 10 2003, 12:35 AM
Thanks!
Bleyseng
Sep 10 2003, 08:34 AM
Use a drill bit stop to set the depth of the drilling. Drill bits tend to bite and go further than you want in aluminum. You don't want to drill too far like Mike did.
Geoff
