how hard is it to fix the mounting screw if it is broken off...
QUOTE (sk8kat1 @ Mar 7 2006, 07:53 PM) |
how hard is it to fix the mounting screw if it is broken off... |
QUOTE (itsa914 @ Mar 8 2006, 07:12 AM) | ||
Mike, Back when I had my 73 914 the mounting screw broke off the driver side handle. I took the handle off and drilled out where the mounting screw went and I think I used either a 10mm or maybe it was a 8 mm bolt about 3/4 inch long. Put the handle back on with lock washer and nut and every was fine. You couldn't tell unless you were looking for it. YMMV |
