QUOTE (Eric_Shea @ Mar 8 2006, 05:54 PM) |
Don't answer this... Because you don't know the answer. Seriously, it is 'VERY' stud dependent. We have literally 4 different sizes that we drill hubs and rotors with... 5 now thanks to Peter Newman Verbus is the most consistent. Too tight and the splines on the stud will peel and leave an uneven mounting surface. Too loose and, of course the stud will fall right through and then have to be welded into place... heaven forbid you want to add spacers and longer studs later. So the answer is "I don't know." Take the studs and the hubs to a qualified machinest and have them drilled specifically for the stud you're going to use. |
QUOTE (Eric_Shea @ Mar 8 2006, 06:08 PM) |
I believe the machinest uses a vertical mill as well... |
QUOTE |
It's a 14mm stud, I think 14 might be too big |
QUOTE (bondo @ Mar 8 2006, 08:51 PM) | ||
I'll be using a bridgeport and a rotary table. I need to buy a 14mm drill bit to drill out some spacers, I'm just trying to figure out if it can do double duty for 914 hubs. If there's any chance it will, I might buy something better than the bottom of the line 14mm bit. |
