QUOTE(campbellcj @ Sep 10 2003, 04:55 PM)
It seems like it would be pretty easy to paint the tubes before assembly/welding in the car
Not a chance. The welding conducts so much heat into the tubing and surrounding sheetmetal that just about everything near the weld site needs to be primed and painted. We even had the undercoating in the wheelwells catch fire a few times. (we removed the UC later)
On the otherhand, if you are using a pre-fab cage, then just paint it first. If you want a tight fitting custom cage, plan on painting.
regards,
david
