My teener tends to oversteer way too easily, even during relatively tame street driving. Am swapping out the rubber today, and I want to make sure the rear wheel alignment is still OK from when I had the car corner balanced, yada, yada.
I assume the camber is OK since it is set with those funky shims on the outboard trailing arm mounts, but what about toe-in? How do you measure it? What should it be? How do you "zero" the wheels to begin with, ie how do you know they are pointed straight ahead before you start?
Thanks in advance...
John
