QUOTE(synthesisdv @ Sep 10 2003, 06:23 AM)
anyone run IDA's on their 914? I understand that these are race carbs, setup for full on or full off.
thanks,
david
When I purchased my 75 2.0L with a mild cam it had 48IDAs w/37mm chokes. It started easy enough, even in the winter. However, it had a fair amount of low-rev stumble/coughing - didn't really catch until 3k plus and then it really screamed (kinda fun, felt like a hotrod), but it had NO low end torque.
Once I started autocrossing, it became apparent that this was a BAD combination. Low end torque coming out of a turn is a good thing for AX. Sifting through various threads, and receiving direct advice on this board, I fitted 44IDFs w/32mm chokes. These guys know what they're talking about - it brought the engine to life with a much broader and useful powerband. I thought it might sacrifice some upper end power, but it seems just as strong as it was - pulls real hard right up to 6k.
Seems to me the 48IDAs need a big, radical engine destined for a racetrack to realize their potential. I haven't sold the carbs yet if you decide to go that way, but I'd suggest getting more feedback from some other racers first. I think more of them run smaller carbs. You might also want to check the rule book for whatever class you run in.
