Full Version: Lifting a Type IV with a shop crane...
lapuwali
I've lifted plenty of inline engines with my crane, but never a Type IV, or any other flat engine. I need to do this to load it into a truck for shipping. I was thinking of making a sling out of webbing, or something similar. Anyone have any comments?
r_towle
I have done it.
I used rope on the engine bar, and the rear of the tranny...worked great.
I also welded a bar across an olr rear bumper...you can then lift up the whole rear of the car, pretty high too!!
Rich
DBCooper
It's not that heavy, so even a pretty thin web like those cheap tie-down ratchets is enough, just double it to be safe. I go a loop around the bottom front of the oil pump, another around the bottom rear of the the engine behind the clutch flange, and balance those two loops on top in the middle. Simple, easy. I love web, it's quick, flexible, strong, and you can throw it in the trunk and it won't rattle.
thesey914
why not just lift it by hand...it's not that heavy. certianly not for 2 people
MattR
Porcharu
QUOTE (thesey914 @ Mar 15 2006, 02:09 PM)
It's not that heavy for an engine, but it's a pretty good hunk of mass and it would really suck to drop it.
My absolutely complete 2.0 was a pretty good heft for 2 normal sized guys. I would guess it was about 275 pounds (about 9 boxster mufflers?ph34r.gif) maybe 290. I know my Suby is 254 pounds and the T4 was a bit heavier.
lapuwali
This is a mostly stripped 1.7 (no intake, no HEs, no engine mount bar, but has the fan and housing). It's going into a hatchback (a Golf), so we may have to lift it after all. I doubt the crane would clear the hatch.
I'll still use the crane and webbing to hold it up while I pull off the HEs. It's sitting on an appliance cart now.
bd1308
301 pounds with the skid it was on....
b
Jake Raby
We lift em all by hand... It takes 4 times as long to harnass one to lift it than it takes to just get it over with... Brent and I are both about 170 and can do it 10 times a day... Just lift with your legs-
davep
Wow, my friend and I carried a complete 2.0 with tin down and back up a twisted stairwell with no elbow room. Another friend and I tossed a complete 911 engine into the back of his Rabbit GTI. And I'm not a big guy at all.
thesey914
Dave... wink.gif user posted image
alpha434
I carried a type IV up four stories. Uphill both ways.
Don't believe me? I'll take pictures. It's in my apartment.
davep
QUOTE (thesey914 @ Mar 16 2006, 12:30 AM)
younger and foolish, especially with my bad back. But it was a task that had to be done at the time.
DBCooper
QUOTE (alpha434 @ Mar 16 2006, 01:11 AM)
I used to do things like that too. Two back operations ago. I learned the hard way why humans invented tools.
Brian Mifsud
I bolted one of these into my pickup truck last year... it's awefully handy for $100. You can hoist an engine out of a conventional (front engined car) and drop it right down into the bed of the truck. It's rated for 1000lbs and full extension, it will still handle 500lbs.
Really saved my back this last winter moving my wood/metal shop, +2 engines (on engine stand!) etc.
user posted image
zymurgist
QUOTE (r_towle @ Mar 15 2006, 04:51 PM)
Can you lift the back of a 914 with an engine crane without modifying the bumper? I'm always looking for new uses for my crane. wink.gif
Aaron Cox
QUOTE (Brian Mifsud @ Mar 16 2006, 11:57 AM)
user posted image
those are on sale at harbor freight!
