Well the doors went pretty quickly as I re-keyed 3 lock sets the night before. SO it was pop the door panel pull the door latch 1 2 3 and were all done.
THEN came the ignition switch. Early column that of course some DAPO has been into before.
ended up pulling the entire column out to put it on my work bench and continue to wrestle the cables inside the metal column to wiggle the lock assembly out enough to release the latch spring inside to pull the tumbler.
Discovered a hidden splice of the grey wire and tape! no wonder the cable wouldn't pull out. Hey DAPO and to top it off the little pot metal piece that sits under the tumbler came out in 3 pieces.
So it's off to buy a new soldering iron as mine got "Hurricaned".
The Stripper didn't come with an ignition switch so if anyone has a complete assembly let me know. at least the little metal piece under the tumbler.
