so did I screw up I've bleed these to death and read the archieves and bleed them again. no air at all or pedal pressure, did it the one man method .. if it shoots fluid the calipers arn't stuck are they?
Brad Roberts
Sep 10 2003, 05:52 PM
Help me out. How are they mounted ?? Flip them from side to side if you have the bleed nipples on the bottom. Air bubbles rise.. you'll NEVER get the air out with the bleed nipples facing down.
B
tat2dphreak
Sep 10 2003, 06:39 PM
QUOTE(Brad Roberts @ Sep 10 2003, 06:52 PM)
you said it!!!
ChrisFoley
Sep 10 2003, 07:15 PM
QUOTE(Brad Roberts @ Sep 10 2003, 07:52 PM)
No, but you will certainly go through a lot of brake fluid trying.
