Brew
Mar 17 2006, 01:42 PM
Starting last nite, I can hear a relay opening and closing. It sounds like the blinker relay, but both the blinkers and the hazard lites work like they're supposed to.
fiid
Mar 17 2006, 03:24 PM
Mine does that too. Everyone always tells me it's a ground fault.
I've spent a lot of time trying to get my harness sorted out - do let me know if you find a solutions.
TROJANMAN
Mar 17 2006, 03:56 PM
when the lights are on, or always?
Brew
Mar 18 2006, 07:53 AM
Always, except when the blinkers are on. I keep having to check that the blinkers are actually off.
Brew
Mar 18 2006, 04:46 PM
And now, it's not doing it today.
Man, you gotta love a car that heals itself. Now if that pesky tranny leak would go away........
gfulcher
Mar 18 2006, 05:20 PM
Maybe our cars are identical twins: I broke my '72 out of winter storage the other day, and noticed that the blinker relay is not longer rhythmic, but speeds up, slows down.. Doesn't matter if the headlights are on or not.. I'm just going to replace the relay obviously, but would an uneven voltage off of the alternator cause a fluctuation in the frequency of a blinker relay?
Thanks,
-greg-
Tobra
Mar 19 2006, 09:40 AM
If I understand correctly how a relay works, the rate it cycles would change with voltage, but I am not to sharp on electrical. You can get a relay for a '69-'70 for pretty much any VW for $10 that works fine.
