man - i owe everyone for all the help ive had
here is the build sheet
1973 2.0
Body
Butt welded in Steel Flares, cut offs from Dan Calicott 914 RaceCar
Metal worked, and pulled 1" out by Los Panchos Garage
Side marker holes welded up and ground smooth
Freshly Painted
GT front valence, with notch for oil cooler
914/6 Rear DEEP Valence with porthole exhaust cutout. 914/6 rolled tip.
Camp914 Rear trunk Shox
Motor
71x94
2L heads
8.5 C/R
Big cam
1.7 rockers with 911 swivel feet, Aluminum Solid rocker spacers
Scat/Manton chrome-moly cut to length pushrods
Weber 44 IDF's
Mallory Unilite distributor. 12/28 grey/grey advance curve
Mallory Hyfire 6A capacitive discharge ignition
Mallory Promaster E-Coil high output CDI type coil
Aurora 8.5 mm CDI capable spark plug wires
European Racing Header 4 into 1 Header
MOCAL Thermostat controlled sandwich adapter plate
Aeroquip/XRP -10 braided oil lines
Setrab 13"x3" Front Mounted Oil Cooler
Suspension
Front
Koni Red - ext. adjustable
22mm Sway-A-Way (SAW) solid torsion bars
24mm Tarett hollow sway bar
Weltmeister Poly street bushings
72 911 front suspension
M calipers and Carerra vented rotors
Porterfield R4s
Turbo Tie Rods
Rear
PMB (eric shea) 5 lug control arm kit
Weltmeister poly street Bushings
Billstein Sport Valved Shocks
Coleman Racing threaded Perches
225 lb/in springs
16mm OEM swaybar
Mintex Pads
914/6 Solid rotors
Wheels
Street
15x7 Fuchs with 205/50 Yokohama AVS ES100 tires.
15x8 Fuchs with 225/50 Yokohama AVS ES100 tires.
Al reed refinished
Autocross and Track
15x7 Cookie Cutters with Falken Azenis RT-215 Stickies
Transmission
Short Gear Ratio Box
(A) (F) (Flipped ZD) (S) (ZD)
New synchros, sliders, dogteeth, diff. carrier bearings, bushings and seals.
Weltmeister Solid trans mounts
Interior and Extras
Momo Prototipo Vintage wheel
904 combo gauge
Rear Defrost window
Reupholstered Seat.Dashes.Backpad by Evilwerks
Rennshifter
Momo contour leather knob
M&R racing, 5 point camlock race harnesses
Weltmeister Harness Guide Bar
Polished aluminum Gauge Bezels by Spunone
NAPCO front and rear soft targa holders for painted tops
Black domestic carpet
Lighting
Omega h4 housings with Hella 55/100w h4 bulbs
Pilot Automotive driving lights 100w h3 bulbs
Hella 500 914/GT lights. 55w h2 bulbs
OEM European front and rear lenses
