I know that fiberglassing is a cheep way to fix a roten spot but there is a better way that will not allow the rust to spread underneath, typical to FGing, and make the matter worse for the next owner. ALL structural parts need to be structuraly sound and must be replaced by the proper component and this is not a structural repair but will preserve the rusted surface from getting worse and or get eaten underneath the FG without you knowing it! I tripped on this repair info in a Car Culture Deluxe magazine, winter of 05 issue page 22-24, and thought it was the BOMB!
The typical repair surface is a rusted, flaked and pitted area like trunk and passenger floors, bottom of doors ect where sand blasting would be needed and even imposible to do without taking the car appart.
The products to use are:
POR-15 & paint brush
A degreaser, (thinner MEK) & rags
Fiberglass mat
Rust removing equipment, steel brush, scrapper....
The trick is to follow all the manufacturer's recommendations for surface preparation for Por-15 and apply generously to the rust spot. Then, put the FG mat on the repair area followed by enough Por-15 over it to saturated the mat in place. Once dried and ready for the second coat, apply another. Done!
The article had silver Por-15 for the first coat but it dosen't matter; black or silver. The best part is that the Por-15 will stop the rust as long as you have all the rust covered up on top and bottom. One thing that I didn't see anywhere about this product and needs to be mentioned is that the stuff is flamable once cured! Please don't put this stuff on or near hot surfaces like the exhaust!
Thanks for saving another teener.
