motorpants
Mar 19 2006, 05:13 PM
I am in the early stages of setting up a 3.0 914 for a road course (track settings) - I have limited seat time but most of it has been in a 911
I would like to get a little more (some) rotation after the turn-in. As is, the car just ploughs (like a front engine understeer) on the edge of adhesion
I am running 8 inch rubber all around, turbo tie rods, stockish springs
outside rear compression too much?
I just got the car and already understand the attraction - I did a donut skidpad drill in a parking lot and no matter what combo of throttle and lift I could'nt break the rears
Idears?
Josh
Andyrew
Mar 19 2006, 05:23 PM
Stockish springs?
Whatever their lb rate, up it by 40.
Your running a six? 165 progressives or 180's will get you good turn in.
And if you dont have sway bars.. put on on front and rear.
Adjustable would be best...
Tighter the rear, more turn in response
Too tight, it'll come around on you too much.
too loose, plowage (as you know well)
If you have a front bar, and no rear bar, 180's would be good.
If you have a big front bar, 200's would be good, and adjust the front bar where you like it. (big bars are adjustable)
And.. what andy says works too..
Make sure you got good shocks..
motorpants
Mar 19 2006, 05:28 PM
God I love this place
can't wait to do more testing to get it right
thanks a bunch
