Spoke
Mar 26 2006, 08:57 AM
I'm adjusting valves on what I was told is a 1.8L engine. I've checked 2 exhaust valves and found them to be 0.006 instead of >= 0.008 for a 1.8L.
How do I confirm that its a 1.8L engine? Below are the stampings on the top and the bottom of the case.
Thanks,
Spoke
Bleyseng
Mar 26 2006, 09:09 AM
EC means 1.7 but a PO could've installed 93mm p&C's for more hp.
Adjust them to .006
bd1308
Mar 26 2006, 09:10 AM
according to this site's 914 info page, under engine serial numbers,
EC = 1.8L
W,EA & EB = 1.7L
b
Bleyseng
Mar 26 2006, 09:14 AM
Heck, thats what happens when I just git up and am drinking my first cup.....
Spoke
Mar 26 2006, 09:19 AM
Thanks!!!!!!!
bd1308
Mar 26 2006, 09:20 AM
I've been up since 11pm....working third shift has some perks...I get to be the 914 nut while everybody else is reaching for the coffee
b
Cap'n Krusty
Mar 26 2006, 09:33 AM
The valve clearance is the SAME (.006") for all the engines w/o sodium filled exhaust valves. I dunno where you got the bogus information, but it should be corrected before others are misled. The Cap'n
Spoke
Mar 26 2006, 10:01 AM
QUOTE (Cap'n Krusty @ Mar 26 2006, 10:33 AM) |
The valve clearance is the SAME (.006") for all the engines w/o sodium filled exhaust valves. I dunno where you got the bogus information, but it should be corrected before others are misled. The Cap'n |
I was looking at a printed tech article that I got with my 74; not sure where it came from.
quote from article:
First, general rules:
Be sure that you use the correct clearance values for your engine: .006 INTAKE... .008 EXHAUST (for 1.8 and 2.0 litre) (.006 BOTH for 1.7 litre)
END QUOTE
However, from PP tech article:
quote from PP tech article:
Engine Model Intake Exhaust
914-4 1.7L 0.15mm / 0.006 in. 0.15mm / 0.006
914-4 1.8L 0.15mm / 0.006 in. 0.15mm / 0.006
914-4 2.0L 0.15mm / 0.006 in. 0.20mm / 0.008 in.
END QUOTE
So I should do both intake and exhaust to .006.
Spoke
Jake Raby
Mar 26 2006, 10:14 AM
Set them at .006 as the Cap'n explained..
EC is a 1.8
EA is the 1.7
Either way the valve adjustment is the same.
Spoke
Mar 27 2006, 08:00 AM
OK, so I adjusted the exhaust valves to 0.006. Not an issue since the engine is sitting on a stand in the middle of the garage.
Later I checked with my Haynes 914 repair manual and they group the 1.8L engine with the 2.0L at 0.008 for the exhaust. I just love when information from different sources agree.
Spoke
Joe Bob
Mar 27 2006, 08:08 AM
.006 just like my Type I.....
