richardmosselman
Mar 26 2006, 05:08 PM
Hi people-my '72 914 driver's side headlamp low beam doesn't work. Have replaced the headlamp-still no worky. I'm hoping that it isn't the dreaded headlamp switch on the dash (mucho dinero,I hear). The switch does act up -sometimes you have to jiggle it. Any suggestions? I'd like to be able to drive @ night. BTW the fogs, the other headlight and the hi-beams all work. Thanks!
richardmosselman
Mar 26 2006, 05:11 PM
OOps! Electrical prob (I'm not ticklish!)
racerx7
Mar 26 2006, 05:13 PM
Post a wiring a diagram and I will look at it for you.
TINCAN914
Mar 26 2006, 05:14 PM
I might be talkin out of my ass, but have you recenly rewired the signals, marker lights, or brake lights? I ask because my marker lights are shaved, and the rear wires were mixed, and I only had one headlight working, screwed around with the wiring and believe it''s figured out, both lights work... From what others have posted, if things are not wired correctly, that will happen.
Good luck
richardmosselman
Mar 26 2006, 05:16 PM
Nope, haven't touched anything-just stopped working out of the blue.
markb
Mar 26 2006, 05:30 PM
This may be asking the obvious, but have you checked the fuses? Each high & low beam have individual fuses. After that, check the relay.
richardmosselman
Mar 26 2006, 05:43 PM
Thanks,I'll chek the fuses-I didn't know about the separate hi/low fuses. I'm relatively new to the joys of teener ownership.
