toon1
Mar 28 2006, 11:08 AM
I have a vac leak at the runner/ head union. I have replaced the gasket with a new, thick paper gasket. I surfaced the face of the runner where it mates with the gasket with some wet sand paper and a peice of granite tile.
Put it all back together very clean and with a little gasketsinch.
When I fired the motor up it was fine.
But yesterday after my drive home from work I noticed a fluctuating idle, sprayed some carb cleaner in that area on the rpm went up.
Is it possible the runner has a crack??
Bleyseng
Mar 28 2006, 11:35 AM
No, but I bet your fuel injector inner seals are shot....
ClayPerrine
Mar 28 2006, 12:58 PM
The manifold gaskets are not just paper. They are a plastic insulator between 2 paper gaskets.
You need the proper spacer with the gaskets. It won't run right with just a paper gasket.
Bleyseng
Mar 28 2006, 01:15 PM
Well, I have seen the engine tin stick out into where the Phenolic block mounts to the head preventing a solid seal. Check for that....
Bleyseng
Mar 28 2006, 01:58 PM
try a different gasket compound like Copper or Curel to seal it.
