Full Version: sportomatic
bernbomb914
Took the Sport-o-matic trans out of a 77 911 apart and the gear ratios are
C 1st
HB 2nd
R 3rd
Y 4th
Just in case you wanted to know. They look brand new because of the automatic clutch. I think I will use the HB in my trans flipped is there another ratio that would help also?
Aaron Cox
bernie, id like the C if its cheap enuff...
been hunting for a 905 sporto for a while
alpha434
Was it a 905? I would like the automatic clutch assembly to fiddle with... and maybe the case.
bernbomb914
I did not get the clutch assy or bell housing but I have the case.
Aaron is the C gear set a longer 1st?
I was told it came from 77 911 is that a 905?
bondo
What's the R&P ratio?
Aaron Cox
if its from a 77, i want to say that its a 925......... (915 based sad.gif )
but yes. a C is a reallllly tall first - lemme know if you want to part with it
bernbomb914
the ring and pinion is 7/27 ratio
Bernie
