QUOTE(omoore3 @ Feb 20 2003, 04:37 PM)
Also where is the thing located.
fuel pump "should" be on the passenger side, under the battery tray, but you need to get to it from under the car (unless your sheetmetal is all rusted away). wait, you said webbers? hmmm, could be relocated inside the engine compartment, usually under the battery tray. OR, sometimes relocated in the front-trunk. OR sometimes relocated under the gas tank (need to get under the front and look through the hole where you can see the fuel lines coming out of the gas tank ...
not sure about the wireing, try to look it up here :
http://www.914world.com/downloads/914%20manuals/later,
Andy
