Full Version: cooling fan removal
G e o r g e
before i drive to germany, are the 3 bolts that hold the cooling fan on 12 point 5mm? or 4mm? or were these supposed to be a differant bolt all together? wacko.gif
George
bd1308
different bolt...
if you dont know, try the 13mm socket. <
its 13mm.
b
mcbain77
I used the 12 point (triple square) M8 size bit to remove mine. PITA. I stripped one and had to use a bolt remover to get it out. I need a replacement bolt come to think of it.
G e o r g e
never mind, put some better light wacko.gif and found that the 8 mm 12 point was the tool.
George
bd1308
wierd....
on my 2 engines, they have the 13mm bolt.
b
mightyohm
Britt,
There are two styles of fan. One uses the bolts and the other uses the triple square.
