Full Version: Machining early Pedrinis for late car
Tobra
I got 4 early ones and one late one, should I just have the shop machine the 4 "00" ones to match the "01" one, or is there a spec for the depth and diameter to be machined? This is to clear the center part of the brake disc, so should I be using a rotor as the guide to how much material should be removed?
redshift
Less than 14 inches.
I don't pick your questions... you can't really control my answers!
M
sean_v8_914
I would use teh rotor to dictate the diameter of the relief in the rim
