Full Version: 1.8 intakes on a 2.0
Leo Imperial
I broke the retainer stud for the #2 fuel injecter.
Has anyone drilled the third hole on 1.8 intakes and used them?
I have tried to extract the broken stud, but have failed and will need to re-thread. I have the 1.8 intakes stairing at me saying put me in. Their is about 1/3" difference in the injector placement. I don't think it should matter.
SLITS
Just get a 2.0L Plenum & runners..........
Have the setup in Riverside if ya want.
rhodyguy
leo, you broke the stud on the head or the clamp stud for the injector?
k
Leo Imperial
How much?
Leo Imperial
QUOTE (rhodyguy @ Apr 8 2006, 11:04 AM)
k
Clamp stud
SLITS
A bazillion dollars...........
Where you at....need shipping info unless your're local.
I'll PM you cost.......
Leo Imperial
Right coast NJ
rhodyguy
i've got a set of runners too. if ron doesn't want to break up a complete setup i will. no need to reinvent the wheel. lmn via pm.
k
Leo Imperial
Thanks guys
First I am going to look into retapping a a quick fix.
SLITS
Just drill it out, helicoil it and restud...in theory, there is no pressure at that point...only vacuum.
rhodyguy
you can have have one of mine for 1/2 a bazillion $. shipping included! what's a helicoil kit run these days?
k
Gint
Drill out, retap and heli-coil.
rhodyguy
while driving to bton, i got to wondering how you managed to break that stud anyways?
k
Leo Imperial
Got a leak.
Got new seals.
Replaced new seals.
Nut was frozen to stud.
Tried to torQ nut.
Broke stud.
Injecter still leaking.
rhodyguy
tsk, tsk. Aero Kroil. every fastener, every time.
k
Leo Imperial
Dave_Darling
The 1.8 pipes are longer than the 2.0 ones. You'll have to cut them off a bit to get a good fit.
--DD
