solex
Apr 8 2006, 09:14 AM
What a job this has turned out to be. I'm ready to install the heat exchangers and muffler after having a lot of trouble removing the old exhaust and heat exchangers. The PO had drilled and tapped one exhaust stud to 10.5 with a helicoil. I had a hell of a time trying to find a step stud but J.Raby came through. And many thanks to John for the entire exhaust system.
I was also able to diagnose my shift problem with new set of sport transmission mounts and a few bushings.
The following pictures are pre-installation; I will post more when they are finally installed.
BTW, if anyone knows where to get a stainless exhaust flange please let me know.
solex
Apr 8 2006, 09:15 AM
Another
solex
Apr 8 2006, 09:16 AM
One more
rhodyguy
Apr 8 2006, 09:21 AM
looks good. put the warm air elbows on the he's before you install them. the top fastener can be a pain to get in when you're laying on your back and you can't see it.
k
Gint
Apr 8 2006, 11:54 AM
What did you paint those heater tubes with? Both the black and the grey? It looks like factory finish. Are those parts new?
solex
Apr 8 2006, 11:58 AM
Gint,
I had all of the air guides and tubes powder coated.
Dan
Gint
Apr 8 2006, 12:39 PM
They look great.
solex
Apr 16 2006, 04:35 PM
Hello All,
So I'm in the process of putting on my exchaust (a second time) decided to use some new exhuast gaskets this time around. I thought I could get away with using the old copper gaskets but I had too many leaks.
In the process of removing the old copper gaskets I noticed that a PO used a gasket from a 1.8/1.7 on one port and doubled up on another port. In addition, one of my studs had pulled out. This is turing out to be quite a project...
I'm having some trouble removing the "doubled-up" gasket I tried a little heat, a pick and hammer and the things will not budge, any thoughts on how I can remove these gaskets?
Thanks,
Dan
solex
May 19 2006, 02:23 PM
Finally Done, car sounds great and runs well too, but I did alot more then just the exhaust.
(1) New wiring harness from Jeff
(2) Adjusted Valves / Timing
(3) All new shifter bushings, the shift coupler was a pain in the A I had to apply alot of heat to get the shaft out.
(4) New 911 sport tranny mounts
(5) 2 pulled exhaust studs were replaced and 1 10x1.5 to 8x1.25 from Jake.
(6) Backdated exhaust with powder coated air tubing.
(7) Free-up and lubed the auxilary air regulator
Please see the attached pictures.
Thanks all for you help, this was a relatively long project for me, but am very happy with the results.
Next on the docket:
-Install dash cover and button up the dash
-Install passenger side mirror
-install front caplipers
solex
a1
solex
May 19 2006, 02:24 PM
a2
solex
a3
solex
May 19 2006, 02:25 PM
VHT on the header and muffler is holding up nicely looks like following the directions is a good thing
solex
May 19 2006, 02:26 PM
dfsdf
solex
fda
solex
May 19 2006, 02:27 PM
fdsf
Hammy
May 19 2006, 03:12 PM
Everything is so clean
Looks nice
