QUOTE(cobra94563 @ Apr 13 2006, 10:49 AM)
I'm facing a simlar need in about 6-9mo. I found one guy on craiglist, pro but doing it on the side, told me it would start around 2500. My budget is now ~1500. (It may go up depending on how the car comes out.)
I'm in No. Cal, so Mexico is probably not an option for me.
I know it's not the good, but I talked to the Miracle shop 10 miles from my house.
They have base prices for a $500, $900 and $2900 full paint jobs.
The $900 includes spot primer and custom colors. I really curious if anyone has experience with one of these jobs. I mean, assuming you do the prep yourself, they can probably spray better/cheaper than I can, on a first try..??
Yeah, they can spray better than you could, if you've never done it before.
A $500 or $900 full paint job isn't going to be using very quality paint, though. Quality materials are surprisingly expensive (and I'm not talking about super high end stuff).
BUT, the body work is what takes the most time. Getting the panels perfectly straight. Takes a lot of block sanding and care, that takes time, and that's 90% of the cost of a $6000 paint job.
So if you do that stuff yourself, you will save a ton.
I've found it's not worth spraying paint at home anymore. You can get someone to do that work (just the actual spraying of the paint) for $500. That seems to be the going rate here in So. Cal., which has high labor rates. So other parts of the country are likely even less.
For $500, it's not worth setting up some bogus spraybooth in your garage, dealing with the incredible mess, toxic fumes, angry neighbors, etc., IMO. Plus, when you pay the $500, you are also getting a guarantee that the job will be done right - if they mess it up, it's their problem. If you mess up, it's easy to kiss a ton of labor and several hundred $$ of paint and materials away.
I've seen lots of cars that have been done by the low end MAACO, Miracle, One Day, etc. type places. My friend just spent $1800 there in the last year. His car looks like crap! He didn't do any bodywork, only disassembled parts of the car. They didn't straighten out the panels very well, so the car is pretty wavy, there are some visible sanding marks, etc. They used their own cheap paint, and the clear is starting to peel in spots in less than a year.
