Found this chart on a 911 site. Numbers should be the same for 914's. Suprising how much the rate increases with each mm. The difference between the two numbers has to do with where the value of the bar is measured, at the wheel or the bar itself. I did not think that my 21mm bars would have such a high value (227/249)
dr
Front Rates
Torsion Kw (lb/in) Ks (lb/in)
Dia (mm) (Wheel) (Spring)
16 77 90
17 97 112
18 122 138
18.5 137 154
19 152 170
20 187 207
21 227 249
22 273 298
23 327 355
