8b) if you have the intermittend wiper relay harness, you can also run the pump off that, just extend the brown/black wire (trigger from steering column) and use it as the 12V feed for the pump.
this way, every time you pull the wiper lever towards you, you get the 4 run intermittend + fresh water!
NOTE: the brown/black wire was NOT an option on early car, '72 and later, if i'm not mistaken ...
In the 74, how would I know if I have this option. Is the relay 'always' mounted on that upright to the cowl?
Were there many with that option?
Can it be retrofitted?
I have the space-saver spare now because of the GT shroud. I'll need a way to pump wasser. I like the 70's 911 pump idea.
