Ok I think I fixed it!! Thank you everyone for your help!!!
I think I started freakin out was just overlooking the obvious. I tightened the cable more. Now my clutch engages a lot sooner but works great. Before I would push it to the floor before it engaged.
It sucks when you are working by yourself and you don't have another person to push the clutch pedal in. Is there a possibilty this new clutch I installed needed some breaking in thus requiring a cable tightening? The reason I ask is that I don't want to think the garage jacked with my cable also.
You see for lack of time I took it into Austin Veedub to have the speedometer and brake light looked at. Aside from them looking at me like I was a stupid yuppie boy, they told me my speedo cable was broke and it would cost $65 for the part and $115 for the work. I politely told him that I already found the part for $40. He then got short with me, so then I said just look at the brake light and I will do the speedo cable myself.
Anyway when I got it back I almost made it home when I had to pull into a sonic figuring my engine was overheated (it was sputtering). I opened the engine lid to let heat off the engine and saw that my air filter was off and 3 air hoses were disconnected. Then when I put everything back together the clutch wouldn't work. I was pissed but it was easier to fix it myself then try and drive it back out there. It just concerns me because you don't need to remove air hoses to work on the brake lights or look at the speedo cable. Anyway If they loosened my clutch cable then they are deliberately trying to F me!
Thanks again to everyone for your input! I will get better at this stuff oneday and pass your knowledge along to the other young Jedi.
Eric
