QUOTE(lapuwali @ Apr 16 2006, 01:51 PM)
Getting all of your injectors to work will help.
Don't be so hung up on reqfuel. This is just a number, which gets multiplied by whatever is in the VE table for your current map/rpm bin. If you lower the reqfuel and raise the VE, or raise the reqfuel and lower the VE, you get the same amount of fuel. Put another way, the reqfuel slides the entire VE table rich or lean.
This morning I got the car to run with reqfuel of 10ms, 4 injections per pulse and alternating. My AFR was around 15. Much better than a reqfuel of 20ms and AFR around 20. Keep in mind my VE table was touched. Clearly is an injector firing issue that was solved or intermittent... maybe. maybe not.
Ok i'm clueless here. I hooked up the injector part of my stim to INJ1 in my relay board. The LED pulses.
I pulled out injector 2, i saw it pulse fuel when cranking. However something strange happened. When removing the injector there was a tiny pressure release of air/fuel. Right after that my fuel pressure gauge dropped from 20 to nothing. System was powered down. Why would this happen? The injector should remain closed and maintain fuel pressure, even when removed from the intake manifold.
I swapped injector connections from 1,3 to 2,4 and the car still ran. Problem must be with the injectors. So to summarize injectors 1,3 inject, 2,4 appear to have problems.
If one injector has issues will it prevent the other on the bank from firing? The impedence across all injectors is roughly 2.5Ohms so that is ok. The injector are solenoid based. If one injector is mechanically unable to pulse due to a mechanical interference (dirt, etc) will this prevent the other injector from firing.
I datalogged pulling each injector connector, its pretty obvious 2 arent firing.
Should my injectors be paired 1,3 and 2,4 ? I don't think its a connection issue, but just in case does anyone have regular d-jet connectors, new or used they could send out? I wish I had a way to test injectors. Over th next few weeks i'll throw something together with a MSI box and stock fuel pump.
