QUOTE(So.Cal.914 @ Apr 17 2006, 02:23 PM)
Found a five lug front susp. Not a later model, it remindes me of the stock 914-6 binders. Could you Guys tell me where to find a number so I can get parts for this. Thanks for the help.
There is no ID number as such. There are 3 types of ball joint, early (bolt on and VEREY expensive), middle (screw in, with a curved notch in the shaft), and late (with a "v" shaped notch in the shaft. 2 bolt spacings for the calipers (3 and 3.5"), early struts for the early ball joints, middle for middle, late for late. There are Koni struts with fine threads in all 3 types, and coarser threads for other brands of shocks, and struts with a pin at the bottom and no threads on the top for Bilstein shocks. Had enough? There are Konis to fit the coarse threaded struts, and Bilsteins as well, and other shocks to fit the Koni struts, too. Good news is only Bilstein makes shocks to fit the struts with the pin. Bad news is they're expensive. There are A-arms with tabs for the anti-roll bar, and ones without. Of the ones without, there are arms that take an underbody bar, and ones that need mods to work with any bar. Then there's the early arms that won't work with the middle or late struts, and they come both with tabs for the bar and without. The Cap'n
