The weld for the ebrake support broke loose.
Anybody else ever seen this? or had to weld this?
It should be an easy weld job to fix this.
I'm thinking just re-tack it from the back and re-weld
the plate back on.
I wasn't planning on grinding down the top layer
"circles" still attached to the long. I was planning on
using them for alignment, welding over them, and adding a few extra tacks
along the sides, corners, and bottom.
Can't I get away with that or do I need to actually grind
down the circles left behind from the spotseld cutter and
weld fill them in?
--- bill
