QUOTE(vesnyder @ Apr 18 2006, 09:40 PM)
Richard - That worked good, thanks, excepts that one of the studs does not have long enough threads and the mount will interfere with the fly wheel - should the fly wheel be removed before mounting? How about the rear engine tin?
I can't comment on the issue with the length of the stud as I haven't used that exact adapter. I would think it should work. Could it be that it is not pulling tight up enough against the case? I think the flywheel should remain on as I think you would use a flywheel lock tool to keep the crank from turning. I think I have heard that the rear tin might interfear.
Someone else jump in and help as I am at the limit of my knowledge on this.
