QUOTE(spiritedTreiber @ Apr 18 2006, 09:22 PM)
Driving down the road today and noticed my RR wheel smoking and realized the brake is what was smoking. Pulled into a parking lot and let it sit for awhile (hour or so). Got back on the road and it was fine. No more smell or smoke. Any one thing that may have caused this? I was thinking it was the slide pins maybe builing up rust or something. The brake was off while I was driving, so I know it wasn't driver error. Should I be worried about this? What would be the best thing to check out first? The rotor doesn't look all burned up yet and I have a good amount of pad left...
Here is a short list of possible causes for dragging rear brakes.
1) Parking brake lever not fully released. Does your indicator light work?
2) Sticky or frozen parking brake cable (in your case right rear)
3) Sticky or frozen brake caliper. Needs rebuild
4) Rusty or frozen brake pad that won't retract. Lots of rust can do this, usually happens in those places that use lots of salt or mag chloride on the roads.
5) Broken return spring in the brake caliper (for the parking brake lever )
6) Gravel or small rock wedging a brake pad up against the rotor.
This one happened to me.
7) High residual brake pressure in the master cylinder. This could cause either the pair of rear calipers or pair of front calipers or all four calipers to drag. This doesn't seem to match your statement that only the right rear was smoking.
8) Rear brake clearence gap set too tight.
If it happens again, try to determine if it is the inside or outside pad is causing the dragging.
Lyle
