sk8kat1
Apr 19 2006, 08:45 PM
there are 6 holes under there with plastic plugs in them .... there are nuts attached inside the roll bar -- what are they for?
Eddie Williams
Apr 19 2006, 08:48 PM
ski rack
thewheel69
I'm by no means an expert here but I believe they were for some kind of luggage/rack mount... there actually is a bike rack that mounts to these. I know, I have one!
Hope this helps... I'm sure others more knowledgeable will pipe in...
914-8
Apr 19 2006, 08:55 PM
yes, they are bolt holes for racks.
also, look on the windshield header - under the rubber, you can see two plastic rectangular plugs (one on d side, one on pass side). Those are removable, leaving holes to mount the front part of the rack!
So.Cal.914
Apr 19 2006, 09:00 PM
The ski race was a very clean install. One small piece mounted under roll bar and the other mounted to the rear bumper thru the tow eye hole. I had one too.
sk8kat1
Apr 19 2006, 09:57 PM
cool.. well my plan is to fabricate and attach a mouting plate using those holes .. so I can install a 3rd break light w/o drilling into the roll bar itself... at least that's the plan
iamchappy
Apr 19 2006, 10:07 PM
I had a ski rack and used it too, I had it sitting in the basement workshop for years why I tossed it I dont know.
Eric_Shea
Apr 19 2006, 10:11 PM
Ski rack would be cool...
brer
Apr 19 2006, 10:44 PM
like zees.
Joe Bob
Apr 19 2006, 10:45 PM
Mount the third tail light on the engine grill.....
Apr 19 2006, 10:52 PM
funny how the same stuff comes up every other month or so ...
while it is true that the *aftermarket* ski rack uses those holes to mount brackets, that is not their original purpose.
the holes are part of the factory "Hohlraumversiegelung" system and are used to inject insulation foam into the hollow parts of the 914 frame.
see this old thread, or, just do a search on "Hohlraumversiegelung"
http://www.914world.com/bbs2/index.php?show...1&st=&p=entry Andy
gregrobbins
Apr 19 2006, 10:57 PM
QUOTE(SirAndy @ Apr 19 2006, 09:52 PM)
Are you sure? There are threads for a 10mm bolt. If the holes were to inject foam, they would not need bolts.
Apr 19 2006, 11:25 PM
QUOTE(gregrobbins @ Apr 19 2006, 09:57 PM)
no, i'm not sure, but the factory was ...
btw. they're supposed to be plugged and not left open ...
Andy
East coaster
Apr 20 2006, 05:49 AM
The pictured ski rack in the previous post is an aftermarket rack. I had a factory ski rack that mounted to these holes and the windshield frame as mentioned. It was pretty cool, it's a thin tubular chrome rack front and rear with leather straps for the skis. I thought about keeping it just 'cause it was cool, but I sold it to someone who would actually use it. I can't find any pics of it...sorry!
davep
Apr 20 2006, 08:25 AM
Yes, the threaded holes were part of the accessory mount system as are the plastic receivers in the windshield frame. However, do not remove the plastic receivers to use the front mounts. The plastic pockets are there to protect the windshield frame. Do not leave the racks in place for extended periods. The tongue on the front of the rack displaces the rubber seal, and extended use will cause permanent deformation of that very expensive seal.
IronHillRestorations
Apr 20 2006, 08:52 AM
QUOTE(SirAndy @ Apr 19 2006, 08:52 PM)
Sounds like a good explanation, except there isn't any foam inside the top piece of the roll bar.
Apr 20 2006, 10:47 AM
QUOTE(9146986 @ Apr 20 2006, 07:52 AM)
and you should be thankful for that!
it was a factory (dealer?) option to have them actually add the spray foam, it was not done by default.
so, unless the original owner of your car paid extra to have his car all foamed up, you won't have any.
BUT, the important point here is that there are quite a few access holes on the car that were supposed to be used for injecting the foam, plus there's a list of points where they would have *drilled* holes to get into cavities ...
Andy
davep
Apr 20 2006, 12:18 PM
Andy, where did you get this information? I've never hear, nor read that anywhere in the past thirty years.
Aaron Cox
Apr 20 2006, 12:57 PM
anyone need a ski rack?
i got one on my shelf.
JeffBowlsby
Apr 20 2006, 01:08 PM
Dave P, the foam injection diagram is from DGVWP buch, see the post Andy referenced. Here is the factory sk-rack with mounts, hey I like the ability to add multiple photos in s each post!:
Aaron Cox
Apr 20 2006, 01:10 PM
never seen that one before....
i have the style like brer's. that is cool jeff!
Apr 20 2006, 01:16 PM
QUOTE(davep @ Apr 20 2006, 11:18 AM)
how good is your german?
Andy
seanery
Apr 20 2006, 01:18 PM
very cool Jeff!
seanery
Apr 20 2006, 01:19 PM
funny, I have the big book and I don't get nearly as much out of it as Andy does
davep
Apr 20 2006, 03:56 PM
QUOTE(seanery @ Apr 20 2006, 11:19 AM)
That goes for me too. Had the book for 10 to 20 years now. Couple of the guys were supposed to help me get it translated.
This is the ski rack that was available 30 years ago. In stainless though it looks kinda dirty now.
