QUOTE(jporsche914 @ Apr 20 2006, 01:16 PM)
For the past few months on and off there has been a squeeling noise coming from the back of my car and i cant take it any more. What is the best way to remove and install a rear wheel bearing?
Thanks,
James
Buy a pair now and put them in the freezer.
Next, you'll need to pull CV's stub axles and axles. You may want to drop the shock bolt to allow the control arm to come down. You'll then need to drive out the hub. Next take off the caps. You'll then need to drive out your bearing.
-or-
Take the entire control arm off and get the hubs and bearings pressed out and in at a local shop. There's a thread on the subject in the Classics section.
I personally don't like doing that with the arms on the car. A few more bolts (and an alignments afterward... which is probably needed anyway) and it's much easier.
