Eddie914
Apr 20 2006, 05:35 PM
In preparation for installation of the 3.2 into the teener, I'm cleaning up a few items: New SS fuel lines, welding the broken clutch tube, front oil cooler thermostat and brake proportioning valve.
I'm planning on replacing the stock proportioning valve with a "T" and installing an adjustable valve.
What type/brand of valve do other teener owners use?
The Good?
The Bad?
The Ugly?
Lever type ... Wilwood?
Knob type ... Wilwood or SBC or ?
Thanks
Eddie
Eric_Shea
Apr 20 2006, 06:28 PM
What brakes are you using?
JWest
Apr 20 2006, 06:33 PM
Rough_Rider
Apr 20 2006, 06:51 PM
I've the lever style one. It works fine however it only has 5 or 6 detents. Plus when adjusting more to rear the feel goes from a positive click to loose. A couple of times on bumpy track the lever has jumped to full rear brakes, which lead to rear lockups.
IMO go with the twisty type. so long as it holds its position.
Eddie914
Apr 20 2006, 07:12 PM
Eric,
911SC front & rear calipers and rotors
Porterfield R4 pads
Front: 225/50/16 on 16 x8
Rear: 245/45/16 on 16 x 9
Thanks
Eddie
Eric_Shea
Apr 20 2006, 07:34 PM
You may not need one with that set-up but you probably have enough rear brake to warrant one if you want one... I kinda like the set-em and forget-em kind that can take the place of the T.
I use a T with a similar set-up.
Eddie914
Apr 20 2006, 09:30 PM
Thanks All!
Just ordered a "T" and adjustable proportioning valve from JWest Engineering.
Eddie
JWest
Apr 20 2006, 09:54 PM
QUOTE(Eddie914 @ Apr 20 2006, 10:30 PM)
Thanks All!
Eddie
Thanks for the order - you should receive it by Tuesday.
