r_towle
Apr 21 2006, 08:23 PM
Ok,
It squeaks when being depressed.
Here is what we have done.
Removed greased and re-installed clutch cable, no frays, no damage.
Inspected clutch tube welds, all fine.
Removed pedal cluster, removed plastic bushings, and installed brass ones...all except the little tiny one...I missed that...
When I took apart the cluster, I noticed that the spring (the big one around the big tube) this spring had worn its fingerprint into the bottom of the tube...
I sanded that area down.
Re-assembly was with alot of lithium grease...everywhere.
So, it was quiet for a few days...now its back...
Squeaks when pressed.
HELP!!! I may go nuts..thank god its not my car...its the kids car..
I drive it to make sure its ok...so having the tunes up really loud defeats the purpose of the drive...
Rich
Series9
Apr 21 2006, 08:25 PM
Mine squeaks too, but the RS is so loud, I only notice when it's not running.
bd1308
Apr 21 2006, 08:38 PM
until now, I thought that squeak was just a signal that something else was on the virge of breaking....
but i'm glad its not fatal.
b
r_towle
Apr 21 2006, 09:22 PM
Where is Eric...he knows the pedal deals...
Rich
r_towle
Apr 22 2006, 09:02 AM
Nobody???
All the smart people here...and I get no help!!!!
R
r_towle
Apr 23 2006, 06:25 PM
jr91472
Apr 23 2006, 06:45 PM
I got the exact same problem (with the finger print as you described it).
Basically I am hitting that spring with some spray lube when ever the squeak comes back (find some with a long spray straw thingy - and you can do it with out even pulling the carpet up).
I am glad you started this thread as I have considered replacing the spring next time I have the pedal cluster apart. But would like to hear from others.
jsayre914
Jun 20 2011, 10:56 AM
I dug this thread up with the search function
My clutch pedal just started squeaking a few day ago. It is very annoying. The whole cluster was rebuilt by bdstone a few months back. After reading this thread i am assuming its a common problem, and it is not a sign of instant death???
does anyone eles lube the clutch often??
John
Jun 20 2011, 11:06 AM
The track car has a squeaky clutch actuation. The cause of that one is the pivot wheel at the trans.
Sound transmits through the cable well.
I have not been able to eliminate my squeak, but have isolated it.
If some smart person was to put a bearing in the middle of the clutch cable wheel at the trans, it would help a bunch.
Drums66
Jun 20 2011, 11:12 AM
QUOTE(r_towle @ Apr 21 2006, 07:23 PM)
Ok,
Rich
.....could be that 1?
SUNAB914
Jun 20 2011, 12:48 PM
Rich, try spraying with penetrating oil, and make sure its not the pedal board the clutch lever is squeeking on. good luck
ewdysar
Jun 20 2011, 02:14 PM
Ok,
So does my wife...
jsayre914
Jun 20 2011, 03:42 PM
QUOTE(SUNAB914 @ Jun 20 2011, 02:48 PM)
Not sure if Rich still has the problem?
I actually opend a thread from 2006
jim_hoyland
May 9 2016, 05:49 PM
Mine just started squeaking; what is the fix ?
r_towle
May 9 2016, 05:52 PM
Bruce stone is the fix Jim.....
Seems old rusted springs talk....and squeak
jim_hoyland
May 9 2016, 05:54 PM
QUOTE(r_towle @ May 9 2016, 04:52 PM)
This is a rebuilt pedal cluster, maybe a year old ? ?
r_towle
May 9 2016, 06:12 PM
Lube
jim_hoyland
May 9 2016, 07:03 PM
QUOTE(r_towle @ May 9 2016, 05:12 PM)
Lube
OK; remove cluster ? Or lube in place ? Bearing grease ? Or ?
76-914
May 9 2016, 07:41 PM
QUOTE(jim_hoyland @ May 9 2016, 06:03 PM)
Lube
You can do it in car, Jim. Put a healthy drop in the valleys of the spring, step on pedal, repeat as necessary. DuPont Teflon Multi Use dry wax spray might be even better. It's great on garage and sliding door tracks!
jim_hoyland
May 9 2016, 08:19 PM
QUOTE(76-914 @ May 9 2016, 06:41 PM)
Lube
Thanks Kent, Who sells it ?
76-914
May 9 2016, 08:26 PM
QUOTE(jim_hoyland @ May 9 2016, 07:19 PM)
Lube
IIRC Jim, it was Lowe's. That or Home Depot.
r_towle
May 9 2016, 08:58 PM
I got addicted to tephlon lube spray for bicycle chains.
Get it at any bike repair store.
Rich
jim_hoyland
May 10 2016, 05:45 PM
QUOTE(r_towle @ May 9 2016, 07:58 PM)
Rich
Bought some PB Blaster Teflon dry lube today at Lowe's; sprayed the spring and went for a drive. Still sqeaks, is their more to this.....?
