OK...that makes sense. When I 've put my car on jack stands in the past, I've jacked it up one long at a time placing a jack stand under the lifted side and then do the same with the other side. Finally, when I set the 914 back on the ground, I would always get a very small puddle of oil which was always a puzzle. Your explanation makes sense! I just replaced the oil tube seals and valve cover gaskets, so I don't know if it still will leak out.
Using a floor jack, is there a safe spot under the car to jack the rear of the car up evenly (rather than one side at a time)?????
Thanks for the tip,
QUOTE(r_towle @ Apr 23 2006, 05:54 PM)
yup, if its oil...
If you tip it alot...I mean alot (you would have to see inside a case to see what I mean) you eventually will dump the crankcase oil into the valve cover...
Normally, you can take off the valve cover and there is about 1/2 cup of oil in the rocker chamber...the head has a natural angle to keep the oil heading towards the engine...you just overcame that angle...for a long period of time...
After you let it down take off the valve cover on the lower side...let the rest of the oil out, get a rag and wipe off the top of the heaterbox...get as much as you can ...then burn the rest.
Rich
